Weather stripping
Do you have leaking in the rear, also? There are stops back there, which you can turn by hand, but there are also other issues back there, which can lead to leaking. If the weatherstripping looks fine, 99.9% chance it is fine.
Its not the weather stripping! I went to take pictures and looked it all over and it all looks fine. Ill adjust all the stops and that should fix it
Save the manuals!
There are many other things that can cause leaks in the rear. I doubt adjust the stops will change anything. You hay have to get one person in the car and another outside with a hose to find out what's up. If water backs up in the gutters, etc. it can flow under the weatherstripping, etc.
