ls1+ rain puddle=voltage surge and lights flicker on and off?????
So this has happended numerous times now. If i hit a rain puddle when driving my voltage with sure. Voltage maxed out and will jump up and down. Instrument cluster lights flicker on amd off and my lights flicker....if i keep tue lights on too long they will blow. Iv been thinking about wasteing my money on an alternator relocation bracket anyone else have problems like this and its only when its a puddle. Battery is good alternator is good. Power wire along with plastic wire harness is good however the power terminal doeant have the rubber boot on it. Would that cause a problem?
Super Hulk Smash
My car doesn't have that. I just replaced the alternator - found out the exciter wire had been hacked into and it was causing all sorts of problems. I'm willing to bet when you hit water, either your exciter wire is getting wet (sort of top right of alternator) or the power terminal on the back is getting wet if it doesn't have the boot.
But the flickering sounds more like the exciter wire going apeshit.
