Car over heating
Old 12-17-2012, 08:56 AM
combs_425's Avatar
Default Car over heating
I drove my car most the afternoon yesterday. At the end of the day it started overheating. I watched the water temp start climbing. I pulled over and let it cool till I could drive it home. I was thinking it was the water pump because of how it just started out of the blue. I used hp tuners to turn the fans on this morning to see if one was out because I heard one running yesterday. It turns out I can only get one to turn on. Would this cause the car to over heat that rapidly?
Old 12-17-2012, 09:07 AM
bayer-z28's Avatar
Only one will turn on, I believe the other one is for the AC, but I'm not sure. Run the car in the driveway and get it up to temp and see if the fans come on. If they do, you may have a WP issue. Replace the thermostat while you're in there.
I've seen it before where the WP impellers look completely normal, but the car overheats. We put a new WP in and it never got over 190-200. (3rd Gen TPI 350)
Old 12-17-2012, 09:49 AM
combs_425's Avatar
I thought that both fans came on. That the first one at a set temp and the the second at another temp
Old 12-17-2012, 12:28 PM
combs_425's Avatar
Ok I checked the tune and my second fan should come on at 183. I let the car idle until it hit 183 and the passenger side fan dose not come on. Y would one come on and not the other
Old 12-17-2012, 02:28 PM
2000 TAWS6's Avatar
I sucked a couple of plastic publix bags into my fans, both stopped. Check to be sure nothing got wrapped around one or both fans.
Jon
Quick Reply: Car over heating
