Changed AIR gasket
Changed AIR gasket
So i changed the AIR gasket on the passenger side when i changed the spark plugs. I just fired up the camaro and let it get up to operating temp and noticed smoke coming off of the gasket itself. I figured this was normal since it was the first time it got up to oper.temp and its new so i hope i am not the only person to have a new gasket smoke like this.
Did you use any WD40 to get the bolts off?
Mine did the same but I removed for the same reason you did but the gasket looked fine so I reused it. It smoked for a few miles but that went away of it still smoking after one full tank of gas aprox 200 miles you might have an issue
