seat studs
Old 05-15-2013, 05:44 PM
LS1BADZ's Avatar
Default seat studs
Picked up an 02 Camaro roller, the d/s seat studs are missing, are the stock oned welded in?
Old 05-16-2013, 02:40 PM
LS1BADZ's Avatar
Bump..
Old 05-19-2013, 11:52 AM
LS1BADZ's Avatar
Help?
Old 05-19-2013, 07:58 PM
1 FMF's Avatar
when i had my interior gutted, i want to say the seat studs are welded to the body from underneath. mine just stuck out from the floor, seat bracket sat over it, then a ~12mm nut fastened it down. when i undid the nuts to pull all the seats out, never had to get a wrench on the other side to hold the stud from turning. i remember when undoing the seat belts where they bolted to the floor, that bolt went through the floor into a nut that was welded on the underside of the body.
in your case i don't see any reason you could not use a bolt and nut, would just need a second pair of hands or something to hold the other side from turning. make sure you use grade 5 or better and make sure the body where it goes through is still strong.
Old 05-20-2013, 05:58 AM
Spartan7's Avatar
The studs are not attached to the floor itself, they are on the cross braces. Have you pulled your carpet to have a look yet?
Old 05-21-2013, 09:01 PM
LS1BADZ's Avatar
Yea the studs on d/s are missing.
Quick Reply: seat studs
