02 WS6-cranks but won't start????
I drove the car to the parts store only 1 block from home, went into store came out, car wouldn't start. I replaced the fuel filter, then the pump because pressure at rail was only 25lbs. Still won't fire. Check engine light was on pulled a code for TPS, change that. Still won't fire. Today changed air temperature sensor. I took the throttle body off and cleaned the MAF sensor and the cleaned the IAC. The car turns over but doesn't start. I can eventually get it to start but it won't idle on its own. When i try to accelerate or give it gas to get the idle up it dies immediately. Any body have any suggestions please?
you are right, 0 pressure!!! This is the 2nd pump I have put in too. When the first pump didn't work, I called The Pump House, which is where I bought the pump, the guy came out and replaced it said the regulator was bad. So I guess he will be making another trip out to replace this one for a better one!
I will keep you posted.
