Yet another no crank no start issue. Help Please!!
Old 09-02-2013, 11:09 AM
Cobra456hp's Avatar
Default Yet another no crank no start issue. Help Please!!
I hope i'm posting this in the correct forum. I've been reading for 2 days to the point of confusion now. 2002 WS6 M6, no engine mods.. Owned for 4 years, never had a starting issue. yes, the battery is good as is the starter. I have no power to the purple solenoid wire unless I jump at the starter relay. I have power to the 15amp starter fuse and the clutch safety switch when in the START position. If I ground the yellow/ black wire at the BCM it will fire then shutoff. Windows, radio and dash lights all work fine. my front running lights come on with switch even with the E-Brake up, but my map lights are not working. Is this my BCM gone bad? I have taken it apart and all solder connections look good. I absolutely have to have this running as it is my rolling office. Please help soon!!! Thanks
Also, my fuel pump is priming.
Happy Labor Day! Woo hoo
Old 09-02-2013, 03:53 PM
Cobra456hp's Avatar
I had the key switch replaced a couple of years ago. I have 2 sets of keys, neither work. If the resistor part of the switch is bad would my starter fuse still light up in the START position? Seriously considering a '69. Something without all this crap on it.
Update: for some reason my map lights are now working and the running lights aren't staying on with the brake up. Still not cranking though!
Old 09-03-2013, 04:45 PM
Cobra456hp's Avatar
FIXED!!!! FN key switch..
Quick Reply: Yet another no crank no start issue. Help Please!!
