Replacing steering column in '98 Z28
I've been able to push on my steering wheel at the 7 o'clock position for years now and have it collapse a couple of inches. I finally had the dealer R&R my column to tighten the tilt bolts but was told they were just a little loose. He said that I need a whole new column because it's worn at the joint.
I'm leery of inheriting a similar problem from a used column. Anyone know if GM still makes the entire column (P/N)? Can I do any other upgrades at the same time, like a better turn stalk, etc.?
