tough steering
when i bought mine the Power steering pump was shot, but it didn't leak or make noise, it just didn't do its job. Replaced it with one from Autozone about 5 years ago and it is doing great till this day. Also try to avoid fluid with Stop Leak in it, it just makes steering effort harder cause of the additives.
Don't forget to bleed the power steering after you fill it. It is actually really easy, just fill it till the reservoir is full, ensure the front wheels are in the air on jack stands, and then start the car. Make a few lock to lock turns on the steering wheel, then check the level and refill as necessary. After the fluid stops going down, do 20 more lock to lock turns with the wheels in there air to ensure all air is out of the power steering system. Then set the wheels on the ground and do 20 more lock to lock turns, now you are ready for the road. Give it a good heat cycle, park it, and you should have years of worry free steering.
Also, I thought my steering was tight until I replaced the rack. Then realized it needed replacing anyway... Much improved!
