Escalade alternator on our LS1s?
Old 12-03-2013, 10:19 PM
dailydriver's Avatar
Default Escalade alternator on our LS1s?
Are these 145 ampers really a direct fit, bolt-on deal??
Is the 'clocking' of the mounting bolt holes identical to ours, and the top exciter wire connector plug the same exact configuration as ours?
Thanks in advance.
Dave H.
Old 12-03-2013, 10:50 PM
Majestic9C1's Avatar
Yes it bolts on.. you wont be able to use the LS1 Alt bracket though.. and the plug is almost in the same location... but its no big deal.
Old 12-03-2013, 11:06 PM
trans_am7935's Avatar
The AD244 alt are badass and definitely worth the upgrade, i just took mine a step farther and rebuilt is for my sanity's sake
Old 12-04-2013, 01:01 AM
So it bolts directly to the block??
Old 12-04-2013, 07:01 AM
ramairetransam's Avatar
yeah , only two bolts hold it instead of three .u should look into doing the bid 3 upgrade also .
Old 12-08-2013, 06:57 PM
sjsingle1's Avatar
did you check out the sticky on this?
Old 12-09-2013, 04:32 PM
Where is this??
Quick Reply: Escalade alternator on our LS1s?
