power steering leak
Old 05-18-2014, 09:46 AM
Mr Phil's Avatar
Question power steering leak
does anybody know how to replace the o ring that's in between the reservoir and the power steering pump? I was on another forum talking to some people about a leak that I can't find, and a few members suggested that it's probably the $0.75 o ring that goes in between the pump and the reservoir. But I do not know how to access it or where it even is lol. I tried looking under the hood but I could not find it so if anybody has any pictures or a link that would be appreciated thank you
Old 05-18-2014, 02:16 PM
Mr Phil's Avatar
Anyone?
Old 05-18-2014, 04:09 PM
Old Geezer's Avatar
Maybe, try the forum that deals w/ external engine parts??
Old 05-18-2014, 06:25 PM
Freefallin's Avatar
What car? Engine?
Old 05-18-2014, 06:31 PM
The Scammer Hammer
dr_whigham's Avatar
Why is this here?
Moved to gen maintenance and repairs
Old 05-18-2014, 06:39 PM
Mr Phil's Avatar
Ls1 is the engine
Old 05-18-2014, 06:59 PM
peterock98's Avatar
Remove the pump Balancer.Remove the supply and return lines.Remove the pump from the block ,there a 2 clips once the clips are off seperate the pump from the reservoir replace o ring.
Old 05-18-2014, 07:04 PM
peterock98's Avatar
https://ls1tech.com/forums/general-m...mp-set-up.html
Old 05-19-2014, 06:57 AM
Mr Phil's Avatar
Is there some special tool needed to remove the balancer?
Old 05-19-2014, 09:37 AM
peterock98's Avatar
I rented one from auto zone .
Old 05-19-2014, 11:40 AM
Save the manuals!
wssix99's Avatar
The O-ring is an odd size, so if you get it wrong, you could get a really bad leak replacing a really small leak. I don't think this is your problem, though. Typically, we have issues with boil-over. Boil-over would look just like a leading O-ring, except you'll have fluid or residue on the top of the tank.
The O-ring holds back just the fluid in the tank, which is low pressure. It would be highly unlikely that it would leak unless messed with.
Why would you do a thing like that?
Quick Reply: power steering leak
