Need help!!! Tranny/clutch noise!
1967 camaro ls1 t56 swap. I installed this setup in my car got it running and driving. The tranny started not shifting and had
a growling noise when i would push in the clutch. So i removed tranny had rebuilt, had some snchro issues and bent shift fork
Wen i put tranny back in i replaced flywheel,clutch pressure plate, to bearing etc. It had a pilot bushing not bearing so i left it. So now that i got it all back together i drove about 75 miles trouble free.
now I have this god awful growling noise coming thru the tranny when the clutch is pushed in. I have an adjustable slave rod. I have adjusted it in and out thought maybe it was over extending.
it will vibrate thru the whole car when clutch is pushed in. you can let out and push clutch again and it may not do it.
then take off again and it start again. I am at a loss. I have bled eveything twice. changed to dot 4 fluid. ANY ONE ELSE HAVE THE SAME ISSUE?
