Dash pad fixes? *pics*
Based on looking at my bare dash (my upper pad is in a dozen pieces on my back porch), it looks like there is a metal retainer clip in that spot (like the ones that hold the radio bezel in place).
It is either popped loose, which you should be able to press down and it stay down or the plastic tab is broken off, in which case I would say just live with it, if the one tab is broken the others will likely follow if you try to remove the pad.
You could try sliding in a small piece of velcro under there (well 2 technically) to try to take the place of the clip (getting one piece to stick to the plastic dash pad and the other right below it on the metal dash frame), but you risk cracking the dash just fleshing it enough to get in there.
well there is definitely a clip there, I just found that section of my upper dash and can see where the clip broke off, so if it won't move for you either your not pushing hard enough or it is already down all the way and you have some minor heat warpage, either way I really wouldn't worry about it you risk far more damage to it trying to do anything and it's really not that bad.
Vaseline (petroleum jelly) rubbed into it once a month is about the only thing that will keep dash pads (the soft padded part, not the plastic deck lid) from ever cracking........
But who's gonna do that. I know people with show cars that do that. It keeps them looking wet and always soft and flexible. But its a lot of work.
I just bought a new dash pad in factory new condition for my Trans Am....mine has started to crack. Im gonna put a few coats of that on mine and then do it every couple months.
Vaseline works great on boat seats and dash boards......you can buy in large tubs.
Not at all, you rub it on with a rag just like you do with Armor All.....except it actually sinks in and protects it. And it shines. If it works perfectly on boats in sunlight and seawater......leather and vinyl.....it will work just as good on car dashboards.
Ill take pics when my new dash pad shell comes in.....after I apply it.
I parted out a 00 TA, dash pad shattered. Parted out a 98 Camaro, figured it being 2 years older it'd be brittle too. Nope came off nice and easy and is plenty flexible. I wonder if it was replaced at some point, or maybe garage kept. Haven't pulled the one off my 01 TA yet but I bought that car from FL so I'm not too optimistic lol
