Unused vacuum ports
Old 10-31-2014, 04:52 PM
mngoos's Avatar
Default Unused vacuum ports
So I was working on the car yesterday (ps cooler broke)and noticed Ihave to unused vvacuum ports what r they for should I plug them or connect them to something or leave them open
Passenger side of tb
Drivers side of tb
Old 10-31-2014, 05:16 PM
LLLosingit's Avatar
Definitely don't leave them open. I have no idea what they go to and it might help someone else answer that question if you gave more details on what the engine is and what it's in.
Old 10-31-2014, 05:30 PM
Spartan7's Avatar
Those are the coolant ports for the throttle body. The TB bypass is already done, which is why they're open. Put some vacuum caps on them or leave them like they are, it's not hurting anything.
Old 10-31-2014, 05:33 PM
2000 WS6 Formula's Avatar
Location: From Massapequa, New York / Now in Southern California
http://www.ls1howto.com/index.php?article=13
Old 11-01-2014, 12:46 AM
mngoos's Avatar
Thank you and its a 99 camaro ss ls1
Old 11-01-2014, 10:01 AM
It's not mine! woo hoo!
demonspeed's Avatar
They were presumably installed for vehicles in severe cold weather climates to help alleviate the throttle body blade from sticking due to the coolant flowing through them. While I've always put caps on them, I don't think it's necessary whatsoever.
Old 11-08-2014, 12:59 PM
BubaGumpShrimp's Avatar
those ports were used to heat up the throttle body using engine coolant. The heat would keep the throttle blade from sticking closed in cold weather. you can see the coolant hoses in your picture where the two clamps are close together.
Quick Reply: Unused vacuum ports
