'99 Trans Am A/C problems
Hey everyone, my Trans Am's A/C is a little messed up. I turned on the the A/C & it only comes from the bottom. I moved the dial to, "A/C" didn't make a difference. Changed it to, "Max A/C" & it still didn't make a difference. I lost hope & switched the dial to everything hoping to see some type of result. Does anybody know why my air is coming from the bottom not from the top? No type of air comes from the vents on dashboard but all comes from underneath. I just bought the car today. I'm still learning about the LS cars since I just upgraded from a LT to an LS. Any opinions & solutions are welcomed. ('99 Trans Am A4)
[QUOTE=Squirts11;18712719]Most likely, the vacuum line running from the rear of your intake manifold to the passenger side T-fitting has come loose. This will cause your HVAC blower to default to defrost and floor vents only. Reinstall this line and you will have upper vents again.[/QUOTEI
I checked it an it wasn't loose nor it isn't off. Is their anything else I can try?
