Replacing hoses: what about clamps?
I ordered a bunch of rad hoses to replace the factory ones while I go ahead and swap the cam...
I'm hesitant to do it as it is, but figured why not?
I'm wondering though: Will the original clamps still do the trick? Or should I buy a bunch of band clams?
Honestly I HATE the spring clamps, they are NOTHING but a big hassle to remove (or move at all) and half of them snap into a couple pieces when moving them and now you have to waste 20 minutes wrestling a busted clamp of the damn hose. As someone who has done their fair share of work on cooling systems over the years (much of it just standard maintenance) I would never suggest planning to save the clamps, expect them to break and plan accordingly, if they don't then you could re-use them.
as for the band clamps coming loose, well like everything else on a car you should check and re-tighten after a few days if needed. after that you shouldn't have any further issues.
Some replacement hoses have a slightly smaller outside diameter than the factory hoses and the OEM clamps won't seal. Stainless band clamps are the only alternative if that's the case. Might as well plan on buying new clamps and avoiding the hassle of reusing the old clamps and then having to change them out later.
I've been doing a little more research, and it seems spring clamps, or constant pressure clamps are the safer way to go.
Now if only you could find them...
Yes, and the other thing most on here do not realize, (because they either live where it is always warm, or their cars never see the light of day, or the dark of night during the winter months) is that IF you live in the northern tier states, and drive your car in the winter time at all, the spring clamps WILL hold a constant tension over LARGE swings in ambient temps, whereas even the very BEST stainless clamps (even the German/Swedish made deals which do not cut into the hose) will NOT.
Someone once told me (either on here, or another site) that amazon and ebay sell these OEM style spring clamps.
The only other decent option is the Gates heat shrink to seal type clamps, but they REALLY look like a hassle to use (to get a heat gun into the positions needed to heat seal them), and, you HAVE TO cut and destroy them to remove a hose.
LS1Tech Administrator
Received 1,794 Likes
This is correct, the OE clamps are OE for a reason - they work well, under a variety of conditions including some where screw type clamps are not as reliable. They don't need to be checked or re-tightened with a change in the seasons, etc. I see no reason to not use them unless, as mentioned above, the outer diameter of the replacement hoses isn't thick enough to provide a proper seal.
But: when I did my first cam swap, I had a spring clamp leak... I wish I could find a P/N for the spring clamps, but even the dealership doesn't have one.
Do you think reusing the old clamps would be okay?
I'm at work and didn't have time to measure last night... So I may overnight them if they should fit
I have often re-used this style of clamp without any problems. In my experience, it's usually the old hose that has trouble re-seating more so than any issues with the clamp (whether spring OR screw type.)
If she leaks, I'll just order new clamps!
Thanks for all of the help!
So you were right: the hose is the main culprit (which I guess makes sense.... If the clamp is seating into the rubber of the hose, then it must lost some of its clamping power).
I used those OEM-style spring Corbin clamps (round stock) which are even tougher to seat than flat stock bands. I always used the red Loctite 518 flexible gasket on any coolant hoses or thermostats. Never had a leak in dozens of uses over a 10 year period on my classic Mopars. I just found it to be an extra measure of cheap insurance. I always prefer the look of the factory clamps.
