What kind of and what brand of power steering fluid?
Yes I've done a search internally on the site as well as on google and browsed the stickies but do not see a consensus. My 98 Z28 has developed a leak. I have been probably been doing something rather stupid and filling the reservoir back up with what ever dollar store equivalent I can find.
Can I use Dexron 6 ATF in the reservoir? If not what is a good brand of power steering fluid? Is synthetic PS a bad idea?
unless you know your power steering fluid is overheating,
i recommend sticking with a name brand regular "power steering fluid" versus a synthetic. And then if the power steering fluid is overheating, the solution there is a power steering cooler. The GM power steering pumps and seals are supposed to run on PS fluid, not automatic transmission fluid. Either work fine as a hydraulic fluid, which is all that the power steering system is. Using ATF you are spending more money on a fluid with extra additives meant to run in an automatic trans and won't benefit you any using atf in the power steering system. I'd expect ATF to leak more than PS fluid.
In any case, actually fixing your leak is the solution rather than using a fluid that won't leak.
For the gm power steering pump if it's original, i think you're wasting your money on synthetic power steering fluid. If you put a new rack in and/or new power steering pump with new hoses, then from a clean slate using a synthetic PS fluid i could understand. But servicing your PS every ~2 years replacing the fluid with the cheapest store brand I would say is better than running redline/amsoil/rp/any synthetic ps fluid and never servicing that.
You could try the Valvoline Max Life power steering fluid, which does have a mild stop leak additive in it and see if that slows down the leak at all.
Is the leak at the rack (NOTHING, fluid-wise will stop, or even slow that down), or is it at the pump?
It IS good fluid regardless (semi-synthetic), and priced in-between the cheapo discount brands and the premium 'boutique' synthetics (Red Line, RP, Amsoil, etc.).
^^^For mild street driving and drag racing ONLY, yes, you are correct.
For extended road course use, or even 'hot-lapping' on an autocross course, it REALLY matters, and sometimes it takes a premium 'boutique' synthetic p.s. fluid AND a good, stacked plate, air to fluid cooler to keep the fluid from puking out of the p.s. reservoir.
I'm just assuming hes a street driver....no hard core road course racing.
I've stuck with the OEM GM #89021182 PS fluid (AC Delco 10-5030 or 5073). At $8.25/qt it doesn't break the bank to do a 1 qt drain/refill every year. I also use the GM stuff (MTL 88861800) in the M6 transmission ($6.32/qt).
I do a bit of autocross and corner carving and I use Red Line 30404 Synthetic PS fluid. I do have an aftermarket cooler and so far it's been great and kept my power steering quiet. Seems to be a popular choice for the RR/HPDE guys as well. Pricey but you gotta pay to play.
