Rear main seal depth question
I needed to replace the slave cylinder and I figured I would replace the clutch while I was in there. Once I got inside, I found an absolute mess. I think there's 100k miles of clutch dust that mixed with oil and created a 1/2" thick sludge that was an absolute mess. I believe the rear main seal is the culprint and the flywheel was just flinging the slurry everywhere.
Anyway, when I went to install the new seal (which is a completely different design from the previous seal) I accidentally went a little past flush by maybe 1/8". I searched a ton and I've seen people say that the new seal type should be flush like the old one, but I've also seen people say that the new seal should be bottom out instead.
I used the AlignIt tool to install. How deep should the seal be installed? I'd appreciate the help. Thanks!
Rear main seal depth question - pics
I needed to replace my slave cylinder so I figured I'd replace the clutch while I was in there. Once inside, I found the bell housing was coated with a 1/2" slurry of oil and clutch dust. Very nasty. I figured it is the rear main seal that is leaking and the flywheel is flinging the oil/dust mixture everywhere.
I pried the old seal out and used an AlignIt tool to install a new rear main seal. The old one was a different design than my new seal, and when I went to install my new GM seal (GM# 89060436) I accidentally went a little past flush - maybe 1/8" deeper. I did not remove the rear cover. I searched online a bunch and saw some people say that the new seal design should be installed flush (like the previous design), while others say that it should gently be bottomed out. Can you please let me know what depth you recommend? Thank you!
