Tag Light Not Working
Like the title says, bulb was burned out on my 97 ws6, pulled over by the cops. Installed two different bulbs and are not working. Thoughts? What's the easiest way to check w/o tearing off the bumper?
Well coming back with a update. I tried to test it w/ a tester I had. The second I placed it in the socket I heard a popping sound coming from the front of the car and now I have no dash light or tail lights when the lights are turned on.
Checked all the fuses and they're good. Could it have caused a short? Dimmer switch still works, when I turn it all the way up the cabin light comes on, odo and warning lights on the dash still work, turn signals still work, and the headlights still work fine.
Save the manuals!
You should be able to trace the harness as it moves back through the car. I would think there should be a connector for the tag light and side markers behind the carpet in the trunk. (I'm not sure about that.)
If you register on AutoZone's website, they have all the car's schematics (available for free) so you can decode the wires in the connector.
