Turn Signal Flashers
@blackbetty Did you replace the housing or the socket? If you havent replaced the housing with the broken lens, id start there. I tried replacing only the socket and bulb and it only worked for a few months before it corroded again. After replacing the housing and drilling a few small drainage holes, ive been good ever since.
But going back to your main problem, if your hazards work, you just need to replace the flasher.
