Mixing 5w30 with 0w40?
1 Post
It won't cause problems. Mobil synthetics are compatible with each other, and nowdays almost all synthetics are compatible with each other.
Research and learn about them to increase your knowledge base and comfort factor.
Yes,it is ok to mix the two.The 0w part is of lower viscosity than the 5w and will provide easier flow at start-up.The 40 part is of higher viscosity than the 30 part and will maintain viscosity and oil film better at operating temperature than the 30.A 0w40 has a HIGHER viscosity INDEX than the 5w30 and higher viscosity index is always preferred because of higher viscosity stability.
