Cant get in my f#$^ing hatch!
Old 04-03-2006, 02:54 PM
HowellSoccer88's Avatar
Default Cant get in my f#$^ing hatch!
Well the other day, I went to go get the nitrous bottle refilled and the key wouldnt go in to the keyhole in the back. I looked around for a while and kept fidgeting with it and I cant get the damn thing lined up. I dont know where to take it or what the fix is and I dont have a the electric hatch release so thats not a possibility. Any ideas? Thanks guys!
Old 04-03-2006, 07:52 PM
mrhzk35404's Avatar
You mean you dont have the release button on your key fob?
Old 04-03-2006, 08:10 PM
Phoenix 5.7's Avatar
if its like our SS, there is no electric release at all, nevermind one on a key fob(and there is no key fob either). you might have to see if you can see anything from inside the car(if the flap is folded down). if that doesn't work then a locksmith might be ur only option
Old 04-03-2006, 08:45 PM
blky2k2z's Avatar
i had the same problem with mine( its a stripper car so no power ne thing) oil it and slap the key hole area with your hand Thats what i did and it fixed it.
mrhzk35404's Avatar
Damn, No wonder I bought a Trans Am instead of a Camaro
Old 04-03-2006, 08:49 PM
TRIPOWER1's Avatar
you can try some heat valve lube from any gm dealer of some pb blaster, that what i use to free up cylinders at work. just spray it on the key and in the cyl and jam the key in.
Old 04-03-2006, 09:12 PM
As Phoenix5.7 said I do not have the button on the key fob. Its all manual. Thanks guys for the input and I have a few things to try now. If anyone else has had this problem post up!
Old 04-03-2006, 09:14 PM
In Need of Cup Holders!
LukePhillips's Avatar
Its because you took your spoiler off...
Try pushing the electric release button inside the car while someone else pulls up on the hatch simultaneously. Maybe the latch is just hung up on something.
Old 04-03-2006, 09:22 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
I once got a part of a blanket caught in the lock--wouldn't open with key OR fob.....I crawled in the back with a flashlight, pulled the carpeting/material that covers the lock mechanism down, and used a Medium sized FLATHEAD screwdriver to poke at the spring/lock area and got it open after about 2 minutes..hope this helps--I was frantic at first 'til I calmed down and tried this.
Old 04-03-2006, 11:29 PM
Haha Luke you are a ***...I only took it off because all the other kids with Ponies were taking theirs off. (Actually it was just to wax and its back on so nobody murder me!)
If you look up in the thread youll see that I dont have an electric release. nhraman I got your PM and see your post so I will give that a try first. Gotta figure out how to crawl around the nitrous bottle but Ill make it work. Thanks for the input!
