couple of problems.
couple of problems.
I need to know how I locate a sqeaking pully. So far I know its one of the A/C pullys b/c when I remove the belt the squeak goes away. So I just need to know how to find out for sure which one it is.
2nd: my A.I.R. pump just started making the "whirring" noise. I know theres an !AIR mod but does it require removing the pump? will this air delete mod make the noise stop?
thanks for the advice , Josh.
the squeeling pulley is prolly your idler pulley on the drivers side underneath the powersteering pulley, and the !AIR mod can only be done if you have non emission style headers or get block off plates for the stock manifolds. but if you delete the AIR then all you have to do is unbolt the hoses running to the stock manifolds block off the manifolds pull out the hoses and you can leave the AIR pump on the car just get in the fust box under the hood and pull the AIR pump fuse. if you have anymore questions just pm me.
