rattling noise when getting on the gas
Old 04-25-2006, 04:02 PM
KevsLS1's Avatar
Default I don't have a clue..
Well today was AWESOME outside, really nice weather.
So I decided to take the Trans Am out for a rip.
Anyways while driving and giving the car maybe half way? I can hear a noise for a second then it goes away, almost sounds like a rattle , like you know how old trucks have those noises when you really romp on them sounds like a sewing a machine or something? ???
Is this normal? and if you give the gas like keep hitting it to half way or so every second you can hear it.
Old 04-25-2006, 10:40 PM
KevsLS1's Avatar
ttt..
Old 04-26-2006, 01:08 AM
KENS_SS_4's Avatar
Maybe pre-ignition (Knock).
What gas are you using? How many miles? Ever tune the car? Do you use much oil?
Any mods?
Old 04-26-2006, 03:57 PM
KevsLS1's Avatar
car only has 1184miles now (brand new pretty much). BONE STOCK and I use 91 Premium gas.
I was told it's prolly the driveshaft, cuz I notice when coming closer to a stop then hitting the gas again it does a clunk noise, but when going a little faster say 60ish and hitting the gas to maybe half it does like a rattle for like a split second then goes away so maybe it's also the driveshaft and does a little more longer of a clunk at higher speeds?
Old 04-26-2006, 04:02 PM
00'WS6Rocket's Avatar
I was going to say maybe your cats but after looking at "1184 miles" I highly doubt it... maybe heatshield I know thoose like to rattle.
Old 04-27-2006, 03:56 PM
KevsLS1's Avatar
I dunno what the hell it is it's pissing me off lol.
no one else can hear it except for me , it's gotta be the driveshaft, cuz I know when I'm going slow and take my foot off the gas then put my foot back on the gas it does a clunk. so maybe at higher speeds and when gunning it to half way which would cause it to downshift itself maybe it would rattle the driveshaft??? who knows?
Old 04-27-2006, 04:27 PM
Roadhouse's Avatar
You're talking about when at speed and you just squeeze into the throttle and for a split second you here a faint rattle? Mine does it also and it has 104k, it has done it for as long as I can remember.
Old 04-27-2006, 04:53 PM
KevsLS1's Avatar
ya it's very hard to hear unless if cars are on each side of you, it's annoying, what is it?
is it the driveshaft ?
Old 04-27-2006, 05:55 PM
Shamson5.7's Avatar
Id say cats as well. Mine is doing the same thing and usually doesnt make the noise until its warmed up. I no longer have stock cats.
Old 04-27-2006, 09:34 PM
Roadhouse's Avatar
I've replaced the cats at 90k and it still does it.
Old 04-29-2006, 03:16 PM
Roadhouse's Avatar
It must be some sort of shielding under the car rattling because I heard it today from outside of the car while it was idling with the A/C going. Gonna hunt for that sucka when I get off nightshift.
Old 04-29-2006, 03:45 PM
longdaddy's Avatar
the symptoms sound exactly like detonation problems in my camaro.
does it do it when the car is cold? if no and the rattle starts only after you driven it for 10 or more minutes, its likely detonation.
does it seem to do it less or not at all when it's cold outside? if yes, it's likely detonation.
can you get 93 or higher octane where you live? try that if you can.
Old 04-29-2006, 08:52 PM
JD_AMG's Avatar
Not to hijack the thread, but now that were on that topic, could bad/worn spark plugs cause detonation?
Old 04-29-2006, 09:55 PM
Formula_X's Avatar
Default re:
Thats what that is?? The driveshaft?? I have that same "clunk sound" when I decelerate to about 2nd gear, then when I give it gas again, it makes a loud "clunk" sound.... I always thought this sound is from the tranny downshifting into 1st too hard? Is this a major problem that needs to be fixed or no?
Old 04-30-2006, 04:43 AM
longdaddy's Avatar
Yes. other common causes are clogged fuel system (bad pump/filter/injectors), bad tune, bad o2 sensors, bad gas
detonation will sound like a bunch of coins rattling in a coke can. single clank is definitely something else.
Old 04-30-2006, 03:32 PM
If its a clunk, might be tranny mount???
Old 04-30-2006, 05:31 PM
Frosty's Avatar
My car does the SAME thing and I've yet to figure it out. I KNOW it's not knock because I have a scanmaster
Old 05-02-2006, 11:37 AM
Michael02hawk's Avatar
Mine seems to do the same. I do not get the 'clucking' sounds, just the 'faint rattle'.
...and I have no idea why or what it is.
I only get it after the car warms up, & only noticed it for the past year.
I've looked into everything I can think of, passangers dont even seem to hear or notice it.
The only new suggestion I havnt thought about, that was mentioned in this thread, is the fuel pump.
My car has had some upgrades, a little more than bolt ons, so maybe my fuel pump isnt up to snuff anymore!
Old 05-02-2006, 12:56 PM
11SECSS's Avatar
If you guys think its your driveshaft then take it out and check the u joints or switch with someone else and see if the noise is still there.
Old 05-02-2006, 01:03 PM
keliente's Avatar
Probably good old spark knock.
