runs badly when cold, but good when warm
Old 06-06-2006, 07:29 PM
MasnarT's Avatar
Default Cold-crap! Warm-good?
Ok, here is my problem when my car is cold it runs like crap almost like it is
missing until it warms up, Then it cleans it self out and runs great until I turn it
off for a couple minutes and go drive some more and it has to clean it self out again . What could cause this to happen and what are some things can I check on to make it run better....any suggestions
Old 06-06-2006, 07:35 PM
Ell Ess Won's Avatar
Blow it up with a bazooka.
Old 06-06-2006, 07:38 PM
camaroextra's Avatar
im assuming you have an LS1 right?
maybe your AIR system is fucked, thats my guess
or do what Ell ESS Won said
Old 06-06-2006, 07:58 PM
2K2WS6TA's Avatar
In the old days it would be the choke that would cause that, so what on an LS1 serves the same function??????
Old 06-06-2006, 08:03 PM
MasnarT's Avatar
I called some of my friends the only that could get a Bazooka was cylde he is going to show up tomarrow morn with it, The only bad thing is he is a midget and those are big guns, Im thinking I will sit in the driver seat while he shoots it so I can get the full effect, eh. I have a helmet I think I'll wear to it has flames
Old 06-06-2006, 08:54 PM
natronathon's Avatar
the LS1's do run richer when the motor is cold. This may be what you are experiencing. The motors are more torquey down low, but also seem more hesitant when they are running cold.
Old 06-06-2006, 10:24 PM
Tech Resident
ChocoTaco369's Avatar
i'd say his injectors are clogged. engines need more fuel when they are colder because they RPM higher. if his injectors are clogged, it'll act like it's missing when it's cold and once it's hot and it requires less fuel, it'll lean out a tad.
run a 5 dollar can of seafoam through your gas tank, see if that fixes it. i'm serious, even if it doesn't fix the problem, you'll probably pick up an extra 1 mpg.
Old 06-06-2006, 11:05 PM
MasnarT's Avatar
Thanks For All The Info Guys, I'll Try The Seafoam Tomarrow
Old 06-06-2006, 11:10 PM
2MuchRiceMakesMeSick's Avatar
Is this a stock car? What mods have you done? It may be the tune.
Old 06-07-2006, 07:19 AM
FL01SS's Avatar
Tune fixed mine.
Old 06-07-2006, 07:18 PM
Tech Resident
yea man, just dump the whole can right into your freshly filled gas tank. any questions, PM me. (you'll need a skinny long funnel!)
Old 06-07-2006, 09:38 PM
SHINER's Avatar
what hapened to my post about midgets+bazookas=emergency room? Was it deleted or is my computer messed up?? Oh well...
Old 06-07-2006, 09:39 PM
hahhaha thats a ******* awesome sig shinerbock! rock n roll!
Old 06-13-2006, 10:44 PM
MasnarT's Avatar
Well I put the seafoam in m tank and it sure fixed the problem it runs alot better
I guess maybe it was a sticky injector , runs good now --thanks for the help
Old 06-14-2006, 03:21 AM
1sick'98WS6's Avatar
seafoam fixes everything, unless you blow it up with a bazooka... but maybe
