Squeek from the rear when I go over a speed bump
Old 06-18-2006, 04:42 PM
Shirley Temple Drinker
Sgt. Spuds's Avatar
Default Squeek from the rear when I go over a speed bump
What could this be now?
Old 06-19-2006, 09:38 AM
REDWS6ROCKET's Avatar
more than likely your rear control arm bushings
Old 06-20-2006, 03:00 PM
hyeteck's Avatar
Thumbs up
I had an annoying squeek coming from the rear also. It was actually the strut rubber mount on the interior of the car. You need to remove the side rear interior panel, peel back the carpet and I loosened the strut a tad, spray the rubber gromet, bolt and nut with some white lithium also spraying between the gromet and the actual frame of the car, tighten back up wipe excess lithium, put everything back together and that solved the issue. Its always good practice before putting everything back together to rock on the back of the car to make sure the squeek is gone before sealing everything back up.
(It was basically just the rubber against the frame of car generating the squeek)
It was the most annoying noise on the car, but yet the easiest to fix. Just for good habit, I lubed up both sides just in case a week down the road the other starts
