EGR Valve and Bushings?
Old 06-26-2006, 11:07 PM
Renegade's Avatar
Default EGR Valve and Bushings?
I'm looking to buy a 98 Z28 this week. The guy says the only problems are that it needs a new EGR Valve, and it shakes on the highway due to worn Bushings on the Front Control Arm, or so he was told. I was wondering how much this would essentially cost to fix, I'm offering him 9k, but with the problems it will be a more expensive car considering it needs work. Can I tune out and block of the EGR, and how could I do that. I've done some searching but haven't found anything detailed, any info would be appreciated as I'm set to test drive the car in a couple of days.
Thanks in Advance :-).
Old 06-27-2006, 09:20 AM
jmm98LS1's Avatar
You can tune out the EGR valve with tuning software. Cheapest way is to find someone in your area with HPTuners or EFILive that will do it for a few bucks or some beer. For the suspension, if you're not doing the work yourself, plan on spending ~$500-600 to have bushings replaced....it would be a good time to replace the ball joints as well. Call around to get estimates and try to knock that much off the purchase price.
Old 06-27-2006, 05:16 PM
Renegade's Avatar
Yeah I'm hoping to get the EGR tuned out, I doubt anyone in my area has a program to do it, so I might just get a basic tune from Mad Z28 or something. Otherwise I will just replace the valve. As far as the bushings go it sounds like it's gonna cost $400 to replace them... hopefully I can talk the guy down from 9,000 to 8,500 based on the problems, if not looks like I'm gonna continue looking. No way I'm spending 9,000 for a car that needs 5-6 hundred in work.
Old 06-28-2006, 03:23 PM
crazymofo1986's Avatar
the egr u can pull off and clean with brake clean and it will prob fix it. that is if it is stuck because of carbon build up
