95 Z28 missing..?????
Old 07-09-2006, 08:51 PM
mustang93's Avatar
Default 95 Z28 missing..?????
This is a 95 Z28 Camaro......Ok I just bought a NEW opti, Cap, and roter, I installed it put everything back the way it goes......... Go to start it and its doing the same thing it was doing before..???? I have done many of these opti sparks and they all fixed the prob... But this time it is still missing real bad..?????? If I hold the RPM up there a good ways it is fine..??? I made sure the plug wires were all on right and where there sapose to go..?? And everything is the way it is sapose to go.???? ANY other ideas??? I have a set of wires to put on it but I havent yet put them on..??? HELP!!!! Thanks
Old 07-09-2006, 11:32 PM
Alpha-Q's Avatar
Your title scared me man...I thought someone stole your car or something. lol
Old 07-09-2006, 11:58 PM
GEARHED's Avatar
When is the last time you had a serious scan and tune on it?
You may be dealing with some code issues after replacing the opti & rotor with some 'fine' tune needed.
Sounds like its running way too lean so you need to keep the rpms up so it won't sputter.
Also, when is the last time you changed the plugs. With the rest you may also be looking at a valve not firing properly - you have a batch fire not a sequential fire so you'd notice it at lower rpms on sequential vs batch.
Old 07-10-2006, 12:07 AM
mustang93's Avatar
I just bought the car..... I dont think a tune up has been done. It is 150k on it... I checked a few plugs abd they look good, They are autolites....
Old 07-10-2006, 12:42 AM
KrisXpc's Avatar
ew... autolites may be the problem... Tr55's or just plain AC delco's are the way to go..
Id bet money you have a plug wire not on the right plug =P
