2 ICM's in one year?
In Need of Cup Holders!
About a year ago, my car died while driving on the highway and I had to get it towed to a shop. They ended up replacing the ignition control module. Worked like a champ.
Fast forward to now. I replaced the ignition control module AGAIN because it went to crap in my driveway. That little thing was $80 so I dont want to make a habit of replacing these. What could be causing these things to go out?
I would be checking for a possible short somewhere in its wiring. Maybe the insulation is rubbed off somewhere just slightly on its wiring causing it short out under certain circumstances. I'm just throwing out ideas here. Make sure all connectors associated with it are corrosion free also. Are you certain that the module is bad? Can you transfer it to another car and see if it works? Maybe you have a bad wire (kinked, pinched, etc...) and when you replace it the wire is set in a different position making it work again.
