where does ur oil pressure set at?
i just replaced my oil pressure sensor, it went bad last night and shot oil everywhere, but i got it fixed today but the gauge is now reading between the 60 and 90(?) does that sound high?
thanks for the responses, mine has dropped back down to 40 idle 60 running... i think it was the new sensor i put on yesterday hadnt had time to warm up or something... i went back to the garage and they said nothin to worry about and on my way home it dropped back down and has been running normal
Tech Resident
50-60 at cold start, 60 at cruise, 65 at WOT, 45 idling at normal operating temps, 35-40 sitting boiling hot in traffic. gotta love GC 0W-30. it barely ever goes under 40 unless the stop and go traffic is severe, my fans are blasting and it's 90 degrees outside. even then it's only be a millimeter.
LS1Tech Administrator
Received 1,795 Likes
50 at cold start.
30-35 at warm idle in gear on a warm day.
25-30 at warm idle in gear on a HOT day.
20-25 at hot idle in traffic on a HOT day with the A/C running.
40+ at anything above idle.
45-50 at most cruising rpms.
This is all with M1 10W30, stock oil pump, and stock idle rpms.
Originally Posted by stealthair
my 99 vette pressure is low like 15 at hot idle and 25 in cruise, Need a new oil pump????
Ok thanks, where is the sensor?
