Turn Signal
Old 08-06-2006, 11:16 PM
PLucas's Avatar
Default Turn Signal
My driver side turn signal doesn't work properly. When you press the turn signal down to indicate turning left, the light stays on. When I look at the back of the car, the yellow light just stays on. The front sometimes stays on or just turns off. The passenger side works fine. I thought it might be the turn signal switch but I would think both sides wouldnt work, right? I checked the bulbs and they are fine. Any ideas.
Thanks
Old 08-06-2006, 11:33 PM
pHEnomIC's Avatar
I just had that problem last week. Its either a bad blinker unit which is located under the dash or a corroded electrical connector. Mine was severly corroded so i had to clean it out with acetone/electric cleaner anda nail file. It worked after. Iheard you can get the connectors at autoparts stores but i had no luck.
bjamick's Avatar
when that happens thre is a bulb out on what ever side it is stayiing on if the back is staying on then the front bulb is out
Old 08-07-2006, 03:40 AM
misfits's Avatar
i had that same problem, and it was my drl module, cost me a cool $245 for that
Old 08-07-2006, 11:07 AM
bjamick's Avatar
the same thing happened to my car and the front bulb was out thats all it took to fix it so i would try that 1st for money sake
Old 08-07-2006, 06:47 PM
JTF Saint Louis's Avatar
If the bulbs are good, then replace the turn signal switch in the steering column. Check out Summit and Gyrhead for GM Performance parts at 1/2 the cost of dealer prices with the same AC-Delco part.
Old 08-07-2006, 08:17 PM
PLucas's Avatar
I am going to check the buld tomorrow. Thanks for the help.
