Burning oil!!!!!!!
Burning oil!!!!!!!
hey guys I just changed my oil 2k miles ago and I noticed that it sucked over a quart in oil. I have NEVER had any leaks what so ever, and I really don't drive her all that hard (for the most part). This wouldn't have anything to do with bad piston rings would it? I just hope this isn't really bad on the engine life.
Its more than likely the damn PCV system. It's faulty by design, and allows the engine to suck in oil through the intake manifold from the PCV. If you pull your Throttle body off and look inside your intake manifold, its more than likely covered in oil. I know mine was when I checked it a couple weeks ago.
There are a couple solutions. One is to convert to the LS6 style PCV system - it works for some, but not for others. It will also cost you about $80 and involves pulling off the intake manifold, which isn't exactly fun.
The other solution is to convert the PCV system to a breather style system. This is what I am seriously considering doing. Basically you just re-route the PCV hoses to breather filters instead of having them connect to the TB/intake. It should eliminate the oil consumption, as well as keep the top end of the motor cleaner and make it run better since it won't be burning oil. It's also reccommended that you change out the oil cap for a breather element, for extra ventination. It also won't pass state inspection, but its easy enough to reconnect some hoses and make it look factory
Hope that helps.
Hope that helps.
My friends car was burning oil, so my idea don't know why was to sea foam it and replace the PVC valve and he has yet to burn oil in two oil changes and LT1s are know for burning of oil...
Originally Posted by Alpha-Q
Are you sure about that? I thought that LT1 was a stronger motor then LS1 cuz it was iron block. Besides, I heard more oil burn on LS1 then on LT1.
LT1 sucks!!!
Tech Resident
what kind of oil are you running? i'm gonna take a shot in the dark and guess a mobil 1 30W. if you are, i'd recommend a thicker oil, like mobil 1 0W-40 or, my personal favorite, 'made in germany' castrol 0W-30. with the GC (german castrol) 0W-30, your oil consumption problems will lessen, if not completely go away. i'm not burning oil, or at least anymore than any other car would.
yea i seem to have the same problem. i just noticed that my car is nearing the add mark after only 1500miles since oilchange. and the oil is still not even begining to be black.
Originally Posted by Unlimited
I drive a 2002 T/A, I believe it came with the LS6 intake....bottom line is though, will this hurt the life of the engine?
just cause its a stronger motor doesnt mean anythin about it burning more oil
Got a 01 vette that loves to suck about a quart of oil down every month or so and it hardly gets driven. My 98z with 110xxx miles doesnt even use oil but im running high milage in there the vette gets the mobil one.
Tech Resident
haha yeah running mobil 1 5w-30 good guess!! so u think if i bump that up to 40 then that will help/not ruin anything?
i'd go for 'made in germany' castrol syntec 0W-30 from autozone as my first choice. if you don't live near an autozone or cannot find it at an autozone, go mobil 1 0W-40. GC 0W-30 is the better oil, however.
Originally Posted by Disturbedtransam
Looks like I have just ran into this problem myself. Odd thing is I have oil pressure but I was bone dry. No leaks anywhere I could find.
well if you want a good deep roar, expect it to be iron block. sound, strength and less worries on overheating. at least LT1's dont need a girdle to stop the block from flexing above 500hp
Originally Posted by irnbru83
LT1 sucks!!!
