Fuel or Ignition
Fuel or Ignition
Frst off, somwtimes the car runs normal. Every once in awhile, I'll be driving( holdign teh gas steady) and the RPMS will start going down a little. Soemtimes it will drop down to about 1000 RPM or just stall out.When went to start it the other day, It idled for a few seconds then started to drop RPMS aNd attempt to stall. After it does stall, i do have to hold the gas down to restart the car. I had the Fuel pressure checked and it was at 30-35 PSI but the mechanic said it needs to be at 40-45 PSI.
I'm starting to leans toward a fuel problem a this point.
