headlight motor?
Old 11-29-2006, 07:44 AM
1gen's Avatar
Default headlight motor?
first off, yes I know about the brass gear fix. I replaced it with the brass gear and now the entire motor itself isnt working AT ALL, it doesnt even make any noise. It worked for about a week after I replaced it and now it doesnt work at all no noise like its just dead. I checked the fuses and theyre all there and all good. How much do you guys think for a pass side headlight motor? Anywhere I can get one cheap?
Old 11-29-2006, 07:49 PM
Coy
Coy's Avatar
after you installed the brass gear, did you tap in the tabs for the motor to gear housing? If not it probably either seperated, or jammed. I have seen both, but if it seperated you would hear some kind of noise.
I replaced my driver and passenger sides with brass gears, and have had no problems with either with over two years of use.
Old 11-30-2006, 09:27 AM
1gen's Avatar
what tabs? more in depth?
Old 11-30-2006, 11:47 AM
spee's Avatar
There are four black tabs that secure the motor housing to the gear housing.
Check this out: http://www.bfranker.badz28.com/headlightfix/tabs1.JPG
