Check engine light
Old 01-05-2007, 08:55 PM
underated98Z's Avatar
Default Check engine light
Ok when I get under 1/4 tank my check engine light comes on. Checked the code and it states that the left bank is running lean. It only happens when it get under a 1/4 tank. Have anyone experienced this problem or do you think maybe my fuel pump is going bad or something. Thanks
Old 01-06-2007, 02:27 PM
2001NBMZ28's Avatar
Did you look up the code/diagnostics at gearchatter.com? I'm kind to my fuel pump and never let it fall below 1/4.
