car is skipping bad high in the rpms
Old 01-19-2007, 09:43 PM
kyles2000z's Avatar
Default car is skipping bad high in the rpms
tonight i was gettin on it pretty good and the car started skipping pretty bad once i got up to about 4500 rpms. it idles fine and doesnt sound like its skipping when idling, and drives perfect until i hit WOT and get up to about 4500 rpms...what could this be?
Old 01-20-2007, 04:19 PM
RUDE SS's Avatar
A arch in your plug wires? Check them and mabe even check your plugs while ur at it
Old 01-20-2007, 05:47 PM
kyles2000z's Avatar
an arch? explain?
Old 01-21-2007, 01:45 AM
kyles2000z's Avatar
could Seafoam possibly cure this? ive read up on it and i think it could be the injectors cloggin up a littl eover time, after all, i only feel it sputter at WOT high in the rpms.
Old 01-21-2007, 08:08 AM
kyles2000z's Avatar
come on folks....32 views and only one response, someone chime in here! ive done a search and couldnt find a whole lot on this. i dont have the $ to be replacing this and that until i find the problem.
Old 01-21-2007, 09:55 AM
kidcamaro98's Avatar
whens the last time you replaced you Fuel Filter???....that tends to be the problem alot of the times causing skipping in the higher RPMS
Old 01-21-2007, 11:09 AM
kyles2000z's Avatar
im not sure that its ever been replaced, i know i ajhvent replaced it and i bought the car with 54,000 miles...now it has 73,000
Old 01-21-2007, 11:15 AM
i would just change it out and see if that fixes anything.
Old 01-21-2007, 11:25 AM
ErikElvis's Avatar
Def change the fuel filter. Its easy. I know on my eclipse skipping at High RPM's was a result of plugs and wires. I went through about 4 sets
Old 01-22-2007, 05:07 PM
RUDE SS's Avatar
A arc is when the plug wire is not making full contact with the plug. I twas happening with my A4 and I thought it was trans trouble skipping like it was.
