Ideling funny
Ideling funny
Alright some times when im comming to a stop I will put the car into neutral and cost to the stop. Sometimes the rpms goes to like 1500 till I come to a complete stop then it will idle normal. It dont do it all the time just some of the time .If yall could help me it would be great
LS1Tech Administrator
Received 1,794 Likes
Worm gear in the IAC motor starting to wear out, carbon build-up on the IAC pintle, small vacuum leak (from a number of different sources), or TPS issue. Those would be the likely culprits on a stock car.
But your car has a cam and custom tune. That leaves a world of different possibilities open, could be that you still need further tuning tweaks for that cam, etc. Once you get into internal engine mods, diagnosing small idle inconsistancies becomes very difficult.
