Fixed my miss at idle and ticking.....
Developed a miss at idle and a ticking on my 2000 SS and it steadily got worse over the weekend. Turned out to be a plug wire had a tear in it and was arcing to the egr/header connection. Fixed that, fired the car up and i'm still getting a missfire with a louder ticking, after an hour or so I found that the wire harness running to coilpack on the same cylinder was arcing from the pink wire to the heat insulation below. The wire had a small tear in it, wrapped with electrical tape till I can find a better way to fix it and that took care of things. Seems to have taken care of my ticking also. Hope this can help someone with similar problems.
pat
2000 SS, A4, Pacesetter LT's, ORY, MTI lid.
pat
pat
pat
