front wheel bearings - Are they Serviceable?
I know the wheel bearings are enclosed on these cars but isn't there a way to take that cover off the spindle to access the bearings to re-grease them or check for wear? I've got 138,000 miles and run the car hard in the corners daily so I'm sure they need a service or replacement.
They are non-servicable units that include the ABS sensors inside. That way they can charge you more for them. You can get them from Auto Zone and they are easy to replace. An electrical clip and four bolts, once you get the wheel and brakes off.
Changing them is simple Plug and Play. If you have that many miles, drive it hard and are concerned about them then change them. But there is probably nothing wrong with them.
The dealer said they were $265.00 a piece, damn I hate GM sometimes. Well I've got a vibration coming from the front end at over 50 mph. I've replaced the brakes, pads, rotors, calipers and brackets, checked front end alignment, re-balanced the tires, checked the tie rod ends and can't find anything. I'm getting a squeeking sound from the front, left side of the car that sounds like a chewed up wheel bearing so I'll tear into it this weekend and see for sure if that's the problem.
