lost the cap for my brake fluid???
Old 03-14-2007, 02:21 AM
toofless916's Avatar
Default lost the cap for my brake fluid???
i was changing my pads and rotors and i forgot to put the lid to my brake fluid resevoir!!! i drove it a couple miles then opened the hood to check something and noticed it wasnt on there...looked all over couldnt find it so i duck tapped the **** outta the top???
am i in any real danger??? im going tomorrow to the dealer for a few parts but the dealership is about 10 miles away....yall think the ducktape will hold?
Old 03-14-2007, 08:37 AM
On the tree
Sneakyws6's Avatar
Nope it wont hold, go to the dealer and order the right one.
The duct tape will not keep the moisture out of the system, so basically you are going to allow water into the system over time and that will cause the fluid to become able to boil at a lower tempature point, allows rust to start forming in the system.
Go spend the $5 and buy the cap and inside seal.
Old 03-14-2007, 01:36 PM
the dealership is weak ***...they quoted me $40 for a replacement cap...i went to kragens and got it for $5.99...damn dealerships rippin
Old 03-14-2007, 07:03 PM
Formula413's Avatar
That's why it's called the stealership.
Old 03-14-2007, 07:05 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
air is gonna get in...i am not sure if u will need to bleed...i say probably....GET the dealership to do it while u are there.
Old 03-14-2007, 09:30 PM
2002 SS #476's Avatar
Brake fluid is a hydroscopic fluid; moisture on metal lines isn’t a good thing. Get a new cap and I would bleed the system to get new fluid in there to help get all the moisture out.
Old 03-15-2007, 11:58 AM
so u think i should bleed the system? right after i noticed that the cap was missing u put layer after layer after layer of duct tape around the opening...
the car sat over night and it got a little moist outside but i live in sacramento, CA...didnt rain, snow, or anything and first thing in the morning i took it to kragen and picked up a sealed cap....
i dont have alot of time in the world but if you guys seriously suggest that i bleed em then i will??????
Quick Reply: lost the cap for my brake fluid???
