Alternator Issues!
Alternator Issues!
got a remanufactured unit from autozone installed it. doesnt work. checked all wiring everything is fine. eventually my battery completely died. i have done all that i could think of. coud i have a bad one? any ideas?
LS1Tech Administrator
Received 1,794 Likes
Did you have any issues with the little red wire (field/exciter wire) on the top-rear of the alternator? The one with a weatherpack connector... if that wire is broken/damaged/disconnected, the alternator will not charge properly.
Or there is a chance you just got a bad rebuild. I never trust rebuilts from the parts store chains, I've had too many bad ones myself.
