Possible? LT install, No Cats, No Sims, No Tune, NO REAR O2 CODES
I had some QTP LTs and ORY installed in my '99 Z28. No cats, tune or sims. But, the rear O2s (which dont even exist as my car only has two front O2s) don't throw any codes.
Is that possible? Shouldn't it at least throw a No Signal type code?
Also, I could only find one rear O2 harness. Did '99s only have one rear O2?
Thanks!
Thanks!
Thanks and thanks.
I had the headers installed several hundred miles ago. I can not find that other harness.
I'm getting an SES light for other codes such as EGR (installed LS6 too).
In my other thread down below, i told the story of having front O2 codes, and I found that they were bad AND swaped (drivers and passenger's sides).
i have LT's not cats dual exhaust ect. rear 02 deleted. anyhow my car didnt initially throw any codes. then one day ses just popped up. 2-3 times the ses has popped up and its never beenbecause of a bad 02. one a splice in the 02 sensor came undone. and another the wire got to close to the headers and melted some. but everytime its been something with just the wire. ive never got an egr code just the normal 02 bank/ air fuel monitor which both go with the 02 sensors.
Checked it again and they said Bank 1, Sensor 1 s throwing codes.
If that is the passenger's side on mine (meaning they're swapped), then I don't know what the hell. The Bosch 13111 reached all the way to the stock harness, so I took out the extension. I'd think it would be fine.
Think the 13111 will reach all the way to the stock harness on the driver's side from the collecter of my QTP LT's?
yes bank 1 is passenger side i belive. i had the exact same thing. though if you switched 02 to oopsite sides and it through the same code again. then my theory might be right. i did that also and the code still showed the passenger side being bad after i had switched it with the driver and erased the code. i almost think the bank 1 sensor 1 ect is generic for both 02s. i think if either side goes bad that code will come up. thats just my hypothesis. from what you have explained and my experience with the same issue. also note. buick centuries/ GP's/monte carlos of that year all use the same 02 sensors. so you can find those easily in a junk yard. instead of paying the over priced versions from a company.
Sharpe, o2 sensors often get ruined by coated headers, regardless of brand. Some of them kill the o2's in a week, my car took about 500 miles before the front o2's went bad. Something about the coating just doesn't mesh well with the sensor itself. The 13111 should reach from the bung to the connector with some room to spare.
rofl. i have stock 02 sensors and 30k miles on them after headers.. like i said. you wast money on those bosch and whatever else. might aswell waste your money on a tornado air intake thing.
well sharpe. i dont care about what people have said or swear to lol. i go off of the little paper in my desk showing me my codes and i know how i fixed the prob. my car runs fine. so take my advice how you want. not to mention i have the GM Esi techline software. so if anyone wants to really argue i can start copying pasting what GM says lol.
Way to get defensive there bud. Truth be told the info you posted above was incorrect. Bank 1 has always been the driver side of the engine. I've been down the same road as you guys after I put headers on my 99 TA. A thing to remember about O2 codes, they will come and go. You won't have one stay on continuious until it's just flat out junk.
I had to replace both sensors after about 1K miles after I did the headers. since then no issues at all.
Alright! Got it fixed!!! Got it up on a friend's lift last night and it was a quick job. Had a bad extension, but the Bosch 13111's ran all the way to the stock harness just fine (that's reason enough to buy them right there!). Just scanned it again today just to make sure that it wouldn't throw the codes. Even watched them with a data logger, which was cool.
Once I got the driver's front O2 working, the back ones started throwing codes like they were supposed to all along! So, the car no longer has the miss/backfire/buck whatever it was under high load at high RPM (it actually stopped that after I changed the passengers). Also, I notcied that the smell of gas fumes went away, so, I might get better gas milage too. Then again, it might have meant my car was running lean, which means the chance of me blowing it up is now less.
Thatnks for all your help!
EDIT: Oh, and yes, though I cant find the harness, the data logger showed that I have 4 O2 sensors.
And, I unplugged the drivers to see if it really was B1S1 and it was.
