sEcurity
Old 04-18-2007, 11:24 AM
juiced_Z's Avatar
Default sEcurity
my security light is on and it wont let me start my car .How do i fix this i go to work in like 10 minutes
Old 04-18-2007, 12:10 PM
Jon5212's Avatar
Try your 2nd ignition key if you have it, try cleaning the little metal contacts on the key itself.
Old 04-18-2007, 12:51 PM
Midnight F-117A's Avatar
If cleaning the keys does not work...
The wires going to the key cylinder broke off the PASS key II reader inside.
2 options:
go to dealer and spend $300 to replace the key cylinder
-or-
measure the resistance in your key and wire in a resistor of the same value to the 2 small white wires inside a orange heatshrink tubing leading to inside the steering wheel column.
Old 04-18-2007, 05:38 PM
phoenixv8's Avatar
That happened to me one time. I took the fuse from the in gauges out, and then replaced it. It turned right up.
Old 04-23-2007, 03:50 PM
djlackore's Avatar
Default Canned Air
I had the same problem. I bought canned air and sprayed it into the ignition. Now my light does not come on. Its been about aa week.
