What Kind Of Bulbs Are Behind The Gauges On 4th Gens?
What kind of bulbs and how do I take the cluster out to put the bulbs in? Anybody done this before?? Thanks, Mike
Bulbs are 194's, Just pull of the bezel around the gauge cluster and you'll see 4 small bolts holding the cluster in. Remove these and the cluster will just pull out. You'll see several black things on the back of cluster, turn these and pull out and you'll find the bulbs.
Originally Posted by transambrotha
thanks, I'll do that today. Also, how does the fog light switch come off of the bezel, I don't see where it does without breaking it
the bulbs are 194s. the fog light switch has a male/female end that you need to unplug. it is wrapped around with foam padded tape
