Car will not start......Help!
If its not simple like the fuses being blown, it could be corrosion on the positve terminal. Your engine will start fine one second and then bam, you're screwed and it won't start the next time. Check it for corrosion.
test to see if you have voltage from the positive battery terminal to the starter. its 1 wire you should have voltage.
to test the purple wire have a friend crank the car and test the purple wire to a known good ground. if nothing shows up there its on the ignition signal side.
let me know what you get when you test these then we can go from here. this will isolate the problem better and i can help you get threw this.
I'll assume your starter was getting power.
Oh in case I didn't tell you the Security light was blinking so I was going to disable the VATS and see it would crank.
