Changed fuel filter/trans fluid
Ok. bought my TA last oct. with 43k miles, drove it some, stored it for the winter, then got it out this spring. 46k miles on it now.
Last week I changed out the trans fluid and fuel filter. If that wasn't a chore getting that low slung of a car up off the floor and level, I don't know what is!
Looked like the trans fluid had never been changed yet, the case around the drain plug was clean. The trans definately shifted easier with the new fluid, especially going into first gear while coming to a stop.
The fuel filter looked like it had never been touched, so I assume it was the original filter. after I changed it and test drove, it seemed like the car had a noticeable increase of acceleration. Is this my imagination, or would the fuel filter make that much of a difference?
John
John
Yes it can and it did on my car as well. I posted on this site about this around 9-10 months ago and told all of the guys here about the difference it had made. Some that tried this had similar results and some didn't.
Forgot to mention Sea Foam as well. Do a search for this on this site and you will find directions on how to do this. Miracle in a can. In addition to this I sprayed my TB down good with TB cleaner. After I did all of this I couldn't believe the difference.
Originally Posted by JayBirdWs6
Is this the Fuel filter on the drivers side floorboard? Whats the part # because I may have to do mine I just hit 48k.
Yes. Just go down to Autozone or Advance Auto or similar and tell them your car model. Took all of 15 minutes to replace mine but be prepared to have your arms completely covered with gasoline. Wear gloves.
just seafoamed the topend, ran a can of seafoam through the gas tank, and changed the fuel filter. after changing my fuel filter i took it for a test drive. the damn thing ran like a rocket. i have 105000 miles on the car and the fuel filter had never been changed. i thought it was in my head too, until i read your post. seafoam your motor bro. you'll feel it even more.
http://www.installuniversity.com/ins...sity/index.htm
edit:tainted beat me to it.
Originally Posted by jond99
STEP 1: Open your gas cap!!!!!!!!! Save yourself the full coating of gasoline and depressurize the system first!!! I think alot of you out there(myself included) wish they had done this step prior to changing the fuel filter the first time.
LOL. I let my car sit overnight and opened the gas cap all to no avail. I was still covered in gasoline and it poured like a faucet the whole time. This is still good advice though.
