what should my oil pressure be? and sway bar ?
im on the stock pump for an 00 and when its cold the pressure seems to be aroudn 50-60 and warm 40-45.. is that normal?
im also wondering if anyone knows how much to tighten the sway bar bolts.. ?
I know theyre even but i have no clue how to tell if its too tight or loose..
im using mobil1 5-30 syn.. is 25-30 good at idle? isnt that a little low?
i wonder why mine is so high.. oh and when i said cold.. i actually meant the temperature outside..by cold i mean like 50s or below.. the warmer it is the lower the pressure..
