View Poll Results: Do you use an oil additive?
Yes, as often as I can.
5
23.81%
No, not in this lifetime.
16
76.19%
Voters: 21. You may not vote on this poll
Oil Additives
Originally Posted by 180ls1
i run lucas synthetic oil stabalizer i was hooked after the display at the auto parts store.
Originally Posted by BriancWS6
No oil additives here. Just use a quality oil and keep it changed properly and you'll be in great shape.
I use CD-2 Street Legal Oil Boost in my 71, ONLY because zinc needed to protect flat tappet cams has been kicked out of the newest engine oils, and SLOB is loaded with the stuff. Not needed for newer engines with roller tappets, so it's straight GC for the 98.
LS1Tech Administrator
Received 1,794 Likes
Moving to General Maintenance.....
I use LC20 every once and a while (2000 miles or so), and sometimes "top up" my Red Line mix (4 qts. 5W-30, 2 qts. 10W-40) with some SLOB & VSOT (Valvoline Syn. Oil Treatment).
These are the only additives even somewhat approved by B.I.T.O.G., along with Schaeffer's and Torco's moly stuff, and Specialty Formulations' SX-UP.
Originally Posted by ErikElvis
I use LC20 in all my vehicles. Its probably only needed in my civic since I use Dino but its cheap to throw in everything else. The other cars get syn.
