broke a bolt, need help on extracting it...
I was swapping my transmission mount, and the bolt that holds the actual mount to the tranny snapped off real easy. I have no idea what the hell was up with that. Anyways, can anyone give me some advice on how to remove it? I searched around, and it seems that everyone had different suggestions. I know I will probably need an easy out, but can anyone assist me beyond that? Thanks again folks.
Is the bolt below the top of the hole or is it sticking out? Go get one of those cheap extractor kits at sears, drill the center and remove the broken bolt...if the threads are bad, heli-coil it then.
yeah it is pretty even with the hole...is this what you are referring to?
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
I use these from snap-on:
But the best you will find at sears is: http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
It will not grip as well as the snap-on tools, but should get the job done if you didn't gall up the threads, and the bolt just broke.
LS1 Tech Administrator
Moved from advanced tech section.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
thanks guys for all your help! This is what I did. I got an extractor set from the local parts store and got a punch. I flattened the center of the bolt, because I was having a hell of a time drilling it in the center (something about me almost standing on my head complicated things). Once I got a good indention going I was all set. I didnt tap too hard, just enough to wear down a hole, I was hoping the threads were fine, so I didnt want to put any undue stress on the threads. Once I got a good indention, I put some oil on the drill bit to try to lubricate it and keep it from burning up. I drilled in about 10 second increments (to let the bit cool) until i was about an inch in. I put on the left hand thread extractor, and drilled it into the bolt, instant success, it came right out with the extractor. Hope this helps anyone else with any problems they may have. My threads were fine so I am in luck.
