98 TA headlight "ERRRRRRRRRRRR"
Old 08-07-2007, 09:18 AM
SpecterGT260's Avatar
Default 98 TA headlight "ERRRRRRRRRRRR"
Like the title says, i have a 98 trans am. This problem just started last night. when I turned off the headlights, they pass side made a wierd noise that can only be electronically conveyed as "ERRRRRRRRRRRRRRRRR"
also, whenever I use my keyless entry to lock/unlock, the headlights will open, close, and then the pass side will again go "ERRRRRR". Is this an indication that the motor is going out? or is there like a small badger or gopher stuck in my headlight?
Old 08-07-2007, 10:45 AM
Quickin's Avatar
This will fix all the problems. The bad gear causes it all.
http://www.bfranker.badz28.com/headl....htm#FreeGuide
Old 08-07-2007, 12:37 PM
awesome, ill give that a go. thanks
Old 08-07-2007, 12:46 PM
is that link a sticky? cuz it should be
Old 08-07-2007, 02:26 PM
aliensRreal's Avatar
Shoebox and Brent Franker (think that's his name) should both have stickies on here, but I have no clue if they actually do.
Old 08-07-2007, 03:39 PM
Greggy's Avatar
i got a new motor and gear assembly for mine.. $100 off ebay. 100% brand new AC Delco part. The gear flip and gear replacement sometimes don't last all that long, so I went the pay me now route.
Old 08-07-2007, 04:47 PM
Quickin's Avatar
Originally Posted by Greggy
i got a new motor and gear assemble for mine.. $100 off ebay. 100% brand new AC Delco part. The gear flip and gear replacement sometimes don't last all that long, so I went the pay me now route.
Good price. This place www.rockauto.com is the best parts place for our cars. $121.00 left motor and $128.00 for the right motor, AC Delco, brand new.
Old 08-07-2007, 04:49 PM
Quickin's Avatar
I flipped the gear in one of my motors 3 years ago, its still good. But as GREGGY said, sometimes it'll only last a few weeks or months. Worth the try.
Old 08-07-2007, 06:59 PM
just got done doing the fix. worked great.
thanks guys
Old 08-07-2007, 07:27 PM
Copy & Paste Moderator
VIP1's Avatar
Sticky:
https://ls1tech.com/forums/pontiac-firebird-1967-2002/177470-firebird-headlights-all-comments-questions-regarding-headlights-go-here.html
Old 08-25-2007, 08:17 PM
98Bird's Avatar
how long did it take to do the gear flip?
Old 08-25-2007, 09:59 PM
about a half hour. For anyone doing this, the only thing id say is to not manually put the headlight ALL the way up. it puts a little stress on the raiser arm and it gets good and stuck to the shaft. I beat on it for 10 min with a wrench and then just lowered it about a turn then it came right off
Old 08-26-2007, 12:33 PM
Grimlock's Avatar
Is there anybody in Houston Texas that is not doing anything right now, or outo f a job and wants to do this for mine? PM me please if you do. Thanks.
With pay of course.
Old 08-26-2007, 09:30 PM
98Bird's Avatar
lol, damn Fireturd. sometimes i wished i had a Z28 instead. just saw the How-To video and it was really good. gonna do mine tomorrow.
thanks for the tip Spectre. btw, to manually raise it (since it's busted and won't go up)...i just turn the **** right?
Old 08-26-2007, 09:42 PM
Dave Carney's Avatar
Brass gears worked well for me. Did them both last year. No problems.
Old 08-26-2007, 10:15 PM
yeah, there is a hole with a rubber booty in it. pull that off and there will be a space for an alan wrench.
Old 09-16-2007, 12:47 PM
98Bird's Avatar
i've decided to go with the fulltime popup headlight mod. kinda like the look better too and now i can almost tell where the front of my car is. and just found out there's like a half cup of water inside one of my highbeam lamps
Old 09-16-2007, 04:36 PM
candlelit's Avatar
Brass gears doesn't work for me. Just so you know. Looks like I might have to convert the headlights now.
Old 09-16-2007, 07:07 PM
blownta00's Avatar
i got the brass one also. theres a guy on ebay that sells them for like 40 buck
